What is this set up called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2012, 11:10 AM
What is the correct term for this type of suspension? And can I replace the shocks with coil overs and eliminate the leaf springs? I want to upgrade the leaf springs, but was figuring it might be better off going with adjustable coil overs. Also does this look like C-Clip eliminators installed in there???
Any thoughts?
Name:	old computer 468.jpg
ID:	67641   Click image for larger version
Name:	old computer 546.jpg
ID:	67642   Click image for larger version
Old 08-27-2012, 11:25 AM
Wiki Edits: 27
Panard needed
You would need a panard or watts linkage to keep the rear axle from going sideways, bar parallel to axle, axle to the frame, with the fuel cell there might not be enough room for a watts.... Ford 9's also 8's do not use C clips.
Old 08-27-2012, 11:38 AM
Gotcha, so upgraded springs it is..lol
Old 08-27-2012, 02:03 PM
Look again - there's already a diagonal bar between the ladder bars for that function. A Watts linkage on the front of the axle is possible but not mandatory (the mounting bolts for the 9" center section make a nice mounting point for the bracket). A Panhard rod along with the existing diagonal link will cause binding.
Old 08-27-2012, 02:09 PM
Wiki Edits: 27
blurry for me
When I tried to enlarge the picts they were blurry, I held down the Ctl key and hit the plus key, the resize was blurry . after another try to load the picts, I see, It's painted black. just go to adjustable coilovers
Old 08-27-2012, 08:29 PM
So with that torsion bar in it I can just go with a coilover? Cool!!!
What if I added something like this for good measure?
Old 08-28-2012, 09:42 AM
Just to be correct, the diagonal bar is not a torsion bar, it's a diagonal brace that prevents the axle from moving side to side. The short panhard rod in the picture is NOT what you want to do. It simply duplicates the function of the diagonal bar you already have AND since it's a different length, it will cause binding as I described above. Just add coilovers to what you already have. Don't make work for yourself.
Old 08-28-2012, 09:50 AM
Wiki Edits: 27
short panhard
A panhard bar should be as long as possible and parallel to the ground when the car is at ride height , a short bar at an angle can sometimes make the rear end want to steer you .usually not what you want unless you just drive in circles. torsion bars are used in place of coil or leaf springs, chrysler had a lot of front torsion bar suspensions starting in the 60;s Mazda pickups in the 80's and a few newer full sized trucks. one end fastened to the frame and the other to the A Arm, it twists as the car moves up and down,
Old 08-28-2012, 11:47 AM
So just to be clear, what I have will work perfectly with a set of coilovers???
And how do you go about selecting length properly?
Old 08-28-2012, 03:34 PM
Wiki Edits: 27
coilovers
You will probably need new mounting brackets for the coil overs. check out speedway motors and Welder series suspension section. the companies that sell coilovers have detailed instructions to find which ones you need, weight at each wheel, static length , travel needed and Mounting angle all will determine your need. the great thing about coil overs is you can fine tune your suspension.
Old 08-29-2012, 07:40 AM
This is how my shocks mount currently, would this be acceptable or would I need to weld on those mounting tabs?
Old 08-29-2012, 08:28 AM
Wiki Edits: 27
nounts
They look like they should work. Most of the lower mounts have multiple holes for more possible locationsm and if you have enough clearance to other components, hoses. fuel lines, exhaust. etc.
Old 08-30-2012, 08:39 AM
Does anyone know if I can mount a coilover in the exact same position as my shocks pictured above? So I dont have to weld the upper brackets on? Currently the shocks bount via a bolt through the frame so the eyelets are in a front to back position. Or is this too much stress on the bolt without the tabs??
Old 08-30-2012, 12:56 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I gota ask. How long have you had this car? Is this a drag car? Prostreet?
Old 08-31-2012, 10:17 AM
Its a pro street car, i had it about 3 years. Any input on my mounting issue?
What are these called????? 71haulnazz Engine 9 09-18-2008 04:57 PM
What is it called? rumrumm Interior 3 05-11-2007 03:10 PM
What is this called? MoparGuy Garage - Tools 7 02-14-2007 01:32 PM
What is this called? EazyDuzIt102 Engine 44 10-11-2005 11:11 PM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 10:45 PM
