Probably stuck with it
I think you may be stuck if you use a T-10. A couple of friends have them in '32s and have the seats modified to accommodate a shifter. My recollection on a couple of oldies I had 'way back then' was that the tranny had bosses cast in the side and that locates the shifter - with no real back and forth adjustment. Of course you can modify a shift lever but probably would look like ....... crap and would still interfere.
Dave |
Would a Muncie be different?
If I was using a Muncie 4 speed would that allow for more movement of the shifter? I did look over my T-10 transmission housing and with some modification I could move the shift mechanism forward a few inches but that also would involve shifter rod mods. Maybe a better way to approach this is what stick shift transmissions do work out well for 32-34 Fords and can handle 400 / 400 hp / tq.
http://www.rsgear.com/TCase/TREMEC/3550.pdf (home site for above: http://www.rsgear.com/ttc-tremec.html) Not sure I'd even fool around with a Muncie or B-W T10 with Tremec's as an option Dave Last edited by Irelands child; 10-25-2006 at 11:43 AM. Reason: spelling |
| Ford Flathead Six Speed Equipment | DJD | Engine | 3 | 12-14-2009 06:16 PM |
| 5 speed tranny with forward shifter? | Warm_Spit | Transmission - Rearend | 2 | 08-13-2003 08:09 AM |
| 34 Ford Side hood grille/vent? | Pilot34Coupe | Body - Exterior | 5 | 02-28-2003 07:15 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
| stock Ford shifter | 5.0 Fury | Transmission - Rearend | 1 | 09-26-2002 03:36 AM |
