Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what should be a good brake line pressure
Old 05-08-2012, 09:55 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by Augusto
I still have issues with my Ford Expedition taking forever to stop, have already done mostly everything, I'm thinking of measuring the fluid pressure at the calipers front and rear to make sure they are getting enough pressure, I suspect they are not.
what pressure should I expect? I read somewhere that 1.200 psi should be enough, is this true?
thanks.
Typical brake line pressures during a stop range from less than 800psi under "normal" conditions, to as much as 2000psi in a maximum effort. Line pressure can only be increased by either increasing the mechanical pedal ratio or by decreasing the master cylinder piston diameter. In either case the pedal travel will be increased.
Your braking system is no better than your tires and suspension but good quality brake pads/shoes are a must also.
