Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What should I run for initial timing with this setup?
Old 08-03-2010, 07:22 AM
stfinney's Avatar
stfinney stfinney is offline
Every setup and engine is different and likes a different setting. Try setting your total advance at around 32-34 degrees and see how it runs. A little more idle is fine, not much at all. What stall converter do you have? Mine was a stock version and did fine.
