What should I set my timing at?
I'm unsure what to set my ignition timing at on my 305 (early 80s), it has an edelbrock 1406 carb, 2101 performer intake and performer cam (summit but equilivant) and factory HEI dist,. I searched and cant find any information on factory timing specs.
I currently have it set at 14* BTDC base with the vacuum advance disconnected.. Cruising down the highway i can hear a ticking sound coming from the engine, is this pinging? Looking for reccomendations for what to set it at for best fuel economy (factory specs im assuming?). Also, should I be able to crank the engine over by hand with all the valves fully closed (pushrods removed)? I did this while changing my cam and could hear the air bleeding out. thanks Last edited by Anton; 05-11-2006 at 10:34 PM. |
Doc here,
Early 80's 305, with CCC or CCCC Computer (or not), 8 Degrees static . Hook the advance unit back up , Manifold source for power, ported source for economy and smog.. Detonation sounds like marbles being shaken in a can..occurs usually under throttle load, and uphill pulls..Being that far advanced will probably make it run a bit hotter than normal. After you set it for 8 degrees , take it on to the freeway, going up the ramp..Hammer it..If it pings / Rattles.. retard it. If it barks like a dog, advance it a bit.. Don't know what to tell ya about turning the engine over by hand with no valve action..but that doesn't sound right..maybe with a socket and breaker bar..Do a Vacuum Check .. 17 to 21 In Hg and STEADY, Bouncing Rapid Needle indicates burned/Leaky Valves, Guides, or seals.. Do a Compression, 125 to 150 PSI + / - 10% all the way around is good..much lower think rings/ rebuild. Did you break in the cam properly ? 2000 RPM for 5 to 20 minutes? Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| ignition timing (in relation to rpms) | KNanthrup | Engine | 8 | 05-21-2006 04:16 PM |
| ? about what to set the timing at on a 350 sbc. | Streetmaster | Engine | 4 | 09-25-2005 10:30 AM |
| 305ci Timing Gear Marks Do Not Line Up | tcruise | Engine | 9 | 08-30-2005 06:22 AM |
| What Came first Chicken or the Egg, or Carb Adj vs Timing | riesman20 | Engine | 19 | 07-18-2004 10:26 PM |
| Trust the timing light or the timing pointer? | lluciano77 | Engine | 6 | 03-06-2004 01:35 AM |
