what should i use - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 06:03 AM
what should i use
i have a chevy c-10 with a stock 350 nothing speacial in that area but i do have a TH400 with a 2400 stall and a shift kit and i was wondering what would be best for an engine (im not sure where to place this in "engine" or "tranny" forum) i have a choice between a 396 stroker or making my 350 into a 383 stroker i would like power but i know since its a truck too much power could be a bad thing so i was wondering what i should use to get great performance and a good daily driver if you have any other questions feel free to ask thank you for your help
Old 10-22-2007, 06:37 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
If it is a real daily driver; cubic inches is your enemy as far as gas mileage.
I've got 2 old chevy trucks; one is a 63 suburban with stock 400 sbc w/HEI, TH350, 2.76 gear & Quadrajet.
The other is a 66 3/4 ton pickup 4WD, 350 w/edelbrock & points ignition, Th400, 3.21 gear.
The 4wd gets better mileage than the 2wd suburban
I should not use the term "better" as they both are gas hogs and I don't use either one unless I need to haul something.
Edit; I also have a good 396 from a factory 69 c-10, but I'll probably never use it due to the rising fuel costs.
Old 10-22-2007, 03:03 PM
well the cost of gas doesnt bother me too much i guess im asking if a 396 stroker is too much power for a c-10 to be able to put to the ground efficiently because i dont have the many for anything really speacial i do know i have a 86 suburban with 4.40 gears in it and i and going to swap out the rearend with that when i chose my engine
Old 10-22-2007, 09:15 PM
which one
I like the cubic inch's. But are you going to be able to get any performance engine to "stick" the horsepower to the ground with this truck?
Old 10-23-2007, 10:36 AM
well thats what im asking i know my truck will be light in the back as is all trucks but with my tranny set up would a larger engine be a good choice i can always get better rubber for my truck
