what should vacuum be - 350 chevy, 9.3 CR, 236 @ .050 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 09:00 PM
Im trying to slowly get my engine tuned just right.
With a 350 chevy
9.3 CR
236 duration @ .050 cam on 108LSA
base timing in the neighborhood of 20 degrees
what should me Vacuum be at idle.. at .. 1500rpm..?
trying to figure if I have a vacuum leak, and also if my vacuum isnt right, to adjust how rich /lean my carb should be..
please help, im new to the concept here
thanks
Old 06-24-2012, 11:36 PM
Originally Posted by F-BIRD'88
recurve the distributor to allow 24 to 26deg base timing at idle.
A short limited 10deg advance curve allows this. (26 +10 ='s 36 total WOT advance)
It should have about 6" vac at idle when idling in gear.
800-900rpm in gear.
A stock torque converter will not work. Get a 10" 3500 stall converter.
Reset the carbs throttle position at idle for .020" fuel transfer slot exposure at idle.
Pri and sec.
Use a 4.5" rated power valve.
The more idle timing you give it the nicer it will idle and the better the throttle response at low rpm.
May even like the distributor advance curve simply locked out.
34 to 36deg locked. You are on the border line for this.
give the motor all the idle timing it wants to idle clean.
Thanks again Fbird for your advice.
This motor loved the high base timing u suggested, but at 3rd or 4th gear, when id back of the gas, I was getting massive detonation. I have a 3,000 stall already.. is that not high enough and causing the detonation?
Pri and sec.
Use a 4.5" rated power valve..
Ill give this info to my carb guy so he can set my carb up proper
its a rochester Qjet
and yea I noticed it idles pretty ****ty with low timing. THe higher timing, it sounds much better. I only changed it back to low initial because of the detonation.
is 6" vacuum in gear enough for my power brakes? or do I need a pump..?
thanks Fbird
Old 06-25-2012, 06:31 AM
ocean-angler/f-bird'88---question
i have a 383 / 700r4 with the same cam spec. except 110°lsa.
i have 31" tires with 4:56 gears.
presently running a 12" 2500 stall, should i also have a 10" 3500 ?
oh, i have the 4150 holley 770 street avenger / 4.5 pv
my timming is as f-bird'88 suggested.
not to hi-jack this thread , i hope .
thanks ROGER
Rebuilt 236 Chevy six problem jpd37 Engine 9 07-19-2011 09:59 AM
big block chevy casting 236 kennyhammond Engine 8 04-24-2011 01:53 PM
13"-14" Vacuum with 220/230 @ .050 Duration Cam? acr Engine 8 05-02-2006 08:06 PM
Where is the vacuum on my 350 SB Chevy? frankenvette Engine 3 04-09-2005 09:53 PM
Vacuum Trouble - Chevy 350 Fragzem Engine 2 11-08-2003 10:37 PM
