Hers a question i forgot to put up here. If you have a bigger tank-it will hold mor air than a smaller tank,---So example' at 45 lbs delivery a 40lb tank will deliver air twice as long as a 20lb tank at the same delivery pressue 45. am i figuring this right??????And is your tank heavy?. mine small one, must be 20lbs. and its steel which would be safer than aluminum????? thank you for your help bob s
