What size bolt is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2012, 05:11 PM
I am working on a front bumper bracket on a 1973 Vega. I am trying to attach the bracket to the frame. A 3/8 bolt is too small and a 7/16 bolt threads in about an eighth of an inch and siezes up. You can still turn it but it is very difficult. I cleaned the threads and applied a lubricant. I thought it might be a metric bolt but I did not think they used metric in 1973.
Anyone know how to determine what size bolt I need?
Old 12-29-2012, 05:42 PM
LATECH's Avatar
Sure sounds like a 10 MM to me. Prolly 10 X 1.0
Fact is stranger than Fiction
Old 12-29-2012, 05:52 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
early 70s used metric and sae ,my cutlass I bought new,metric bolt heads are blue standard ere black or natutal ,hope this helps I am thinking Metric 10mm
Old 12-29-2012, 07:53 PM
Probably metric. some common metric sizes, M6 x 1, M8 x 1.25, and M10 x 1.5
I think M10 x 1.5 is probably what you have. A Metric 1.0 thread pitch is pretty fine.
I am working on a 1970 Datsun, engine bolts are metric, body bolts are SAE, and engine hydraulic fittings are a British standard.
Old 12-29-2012, 11:21 PM
You need a good thread gauge and better yet a tap and die set so you can check thread and clean them up.
Old 12-30-2012, 07:00 AM
Banned
isn't the vega an opel based car?
'd not be shocked at all to see metric bolts on it..
Old 12-30-2012, 11:11 AM
Nope, not Opel based, made and designed right here.
Old 12-30-2012, 11:38 AM
Banned
The Vega was conceived in 1968 to utilize newly developed all-aluminum die-cast engine block technology the first sand-cast aluminum blocks had preceded the decision to build the car by two years. A relatively large displacement engine with good low- speed torque was decided on, with gear ratios for low engine rpm to achieve economy. Engine testing totalled 6,000,000 miles. A pre-test engine was installed in a Fiat 124 sedan for development of the aluminum block, while several 1968 Opel sedans were used for drive train development[9]
Chevrolet instituted a new management program, the car line management technique, to produce the all-new car in two years. The chief vehicle engineer had overall charge of the program. 50 engineers, dedicated to the design of the entire car, were divided into groups: body, power train, chassis design, product assurance, and pleasability. The latter would check continuously on the vehicles on the assembly line, with computers in another program monitoring quality control of every vehicle built.[9] Fisher Body engineers and draftsmen moved in with the Vega personnel.
In October 1968, there was one body style (the "11" style notchback sedan), one engine, one transmission (MB1 Torque-Drive manually shifted two-speed automatic), one base trim level, a bench seat, molded rubber floor covering, no glove box or headliner and no air-conditioning (ventilation was through the upper dash from the wiper plenum). As the market changed, so did the car in development.
December 1968: Hatchback, wagon, and panel delivery styles added; also floor-level ventilation, and an optional performance engine ("L-11" two-barrel) which, predicted as 20% of production, accounted for 75%. Bucket seats were standard. Hatchback and wagon received carpeting and headliners. Optional air conditioning, predicted as 10% of production, rose to 45%.
February 1969: Opel three- and four-speed transmissions (three-speed standard, others optional); Powerglide also added (now four transmissions); mechanical fuel pump replaced by in-tank electric pump; power steering option; base "11" style notchback trim upgraded to match hatchback and wagon carpet and headliner.
April 1969: Gauge-pack cluster, HD suspension, wide tires; adjustable seat back (45% of production); bumpers restyled, lower valance panels added; swing-out quarter window option (10% of production).
July 1969: Electrically heated backlite option (10% of production); "GT" package, $325.00 extra (35% of production); bright window-frame and roof drip moldings added to hatchback and wagon.
This is essentially how the car launched as a 1971 model. Production began on June 26, 1970. After the national GM strike (September to November 1970), bright roof drip moldings were added to the base "11" notchback, with moldings sent to dealers to update units already in the field.
Cars magazine said in 1974 that in the rush to introduce the car with other 1971 models "[t]ests which should have been at the proving grounds were performed by customers, necessitating numerous piecemeal "fixes" by dealers. Chevrolet's "bright star", received an enduring black eye despite a continuing development program which eventually alleviated most of these initial shortcomings.
Old 12-30-2012, 11:47 AM
Um... ah.........I never knew that! However, was there any Opel design work or being GM owned Opel did they simply use the cars to test the Vega engine? Hmmmmm It says "The chief vehicle engineer had overall charge of the program. 50 engineers, dedicated to the design of the entire car, were divided into groups: body, power train, chassis design, product assurance, and pleasability. The latter would check continuously on the vehicles on the assembly line, with computers in another program monitoring quality control of every vehicle built.[9] Fisher Body engineers and draftsmen moved in with the Vega personnel."
Nowhere does it say "Opel designed"? I guess Opel and GM were sort of one in the same being everything done at either one was open for the other to see, were they "one"? I don't know but you bring up an interesting point non the less.
Old 12-30-2012, 12:15 PM
Banned
just like today, when we don't have it, they go looking within..
the underpinning of an opel looks like almost a carbon copy..
and the opels are late 60's so?
g.m. was great for taking a platform and spending tons to upgrade it..
for this market
the chevette is from the same mold,, take opel and rework it some ad bamm, new car
Old 12-30-2012, 05:15 PM
Bolt size is 10mm.
I put a tap in the hole and you guys were right. It is a 10mm. Thanks so much for the help.
Exhaust Bolt Size seawolf18 Engine 2 06-29-2011 10:13 PM
Bolt size on TH350?? 78monte85riv Transmission - Rearend 4 09-25-2009 10:28 PM
What size bolt???? hmmm Engine 2 04-27-2008 09:08 AM
10 bolt carrier size ID?? chimera555 Transmission - Rearend 3 08-19-2007 11:19 AM
Bolt size 70 Cad Engine 2 06-20-2003 06:36 PM
