What size bolts to hold a 390 on a stand? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2012, 02:42 PM
Im about to start rebuilding a ford 390FE from a 68 Stepside, I need to know what size bolts i need to go into the block on the stand. I apologize if this isnt the right section but im new.
Also will my 750pound stand hold it? someone told me it was 650lbs with everything on it
Old 04-05-2012, 04:01 PM
Wiki Edits: 31
Ford usually used 7/16". That's what is holding my 460 to it's stand..
750 LBS stand will hold it if it's a 4 wheeler. if it's a 3 wheeler, I would not reccomend it..
Old 04-05-2012, 04:18 PM
Thanks does it Matt the thread count? I got 14 and how far does it need to go Into the block
Old 04-05-2012, 06:44 PM
Wiki Edits: 31
7/16-14 thread is common course thread in 7/16" and what it would be..
Till it feels tight. 5-6 threads probably. just buy the right length or longer. you can set your depth with washers or a larger nut.
T-350:size of bolts that hold the flex plate cover? blap350 Transmission - Rearend 2 01-10-2012 04:50 AM
How many bolts hold 700R4 to my 1983 SBC ? LOWbutnotSLOW Transmission - Rearend 4 07-05-2009 09:14 PM
Engine stand bolts JG700 Engine 18 05-30-2007 09:18 PM
how good do 10 bolts hold up? Haulin Ace Transmission - Rearend 8 04-20-2007 10:53 AM
engine stand bolts brad_irc Engine 4 08-19-2003 03:09 AM
