Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what size and brand cam should i use?
Old 03-03-2004, 08:14 PM
mj_lover's Avatar
mj_lover mj_lover is offline
expert lurker
Last journal entry: day one!
it all depends on where you want to make peak Hp. do you want peak at a low, high or mid. rpm range? I suggest you find crane cams, they may have some info on there site. I am by no means a chevy explert (i know jeeps/amc) but if you search around, there should be all the info you need.
good luck
