what size and brand cam should i use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2004, 08:02 PM
72chevyhotrodder's Avatar
New Member
what brand camshafts are good yet economical? the cam is going in a stock 350 thats rebuilt 40 over and has a stock cam now.i want to put a bigger cam in it for a little more power since its alittle slow now,what size cam should i use? thank you
Old 03-03-2004, 08:14 PM
mj_lover's Avatar
expert lurker
Last journal entry: day one!
it all depends on where you want to make peak Hp. do you want peak at a low, high or mid. rpm range? I suggest you find crane cams, they may have some info on there site. I am by no means a chevy explert (i know jeeps/amc) but if you search around, there should be all the info you need.
good luck
Old 03-03-2004, 08:22 PM
GTO 1965's Avatar
Comp Cams XE268H would be a good choice.
Old 03-03-2004, 08:27 PM
lluciano77's Avatar
Comp, Crane, and Crower cams are good. Comp and Crane are moderately priced. Crowers are more expensive. They use more modern technology in their grinds.
There are also PAW, and Summit cams that are decent. I have one in my SBC 400. They are cheap, and they work. They are older technology, but I'm sure they were pretty cool back when the came out.
I suggest a dual pattern cam. You want more flow % from the exhausts when using stock heads. Go for a split lift/duration cam.
Old 03-04-2004, 10:10 AM
New Member
i want a cam that increases low end torque,and since i dont know what size the stock cam is until i pull it out,is there a stock size in a sbc 350?
