What size cables do I need for this amp??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 12:20 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
Okay I dont know much about setting up big loud stereo systems. The only reason why I am putting one in is because a good friend of mine sold his old speakers to me dirt cheap!
I just need to know what size cables I need to hook up the amp (10ga???) and what size fuse (40amp???). Also what size speaker wires from the amp to the sub (12ga???).
I have two 12" subs max wattage 550 each.
The amp is 600 watts at max output.
On a second note. I remember reading somewhere awhile back that you can put a toggle switch on the remote wire I think? So that you can turn off the amp if you wanted is that true???
Old 02-22-2009, 12:43 PM
Go to the Crutchfield site, look under "learn" they have install notes for you. Also there is a wire selection chart for your amp.
Old 02-22-2009, 12:59 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
With a small amp like that I would use a 8ga power with a 40A fuse. The important thing is to use the same gauge ground as the power and keep it as short as possible.
You can put a switch on your remote wire to turn it off but why? If you feel there is too much base just play around with the settings on your radio an on the amp to get the sound you want. One thing to remember though is a good sub will drown out your mids if they are not powerful enough.
Old 02-22-2009, 01:27 PM
What size wire would you recommend for the subs from the amp???
I ask about the switch because I might not want the bass at the time.
Also I completely understand about the subs overpowering the mids. I have a deck that puts out only 50 watts per speaker. I have 2 pioneer 6 1/2".
To be honest I dont want the 12s. I was looking for a set of low wattage 10s to give a little extra bass. But my good friend sold the12s to me at a price I couldnt turn down for the quality of the subs.
I mean could you turn down two 12s 550watts each (dual voice coil) that sound amazing? I couldnt. . . not for 80 bucks
Old 02-22-2009, 03:01 PM
1969NovaSS's Avatar
Is this going in your El Camino?
If you got a great deal on the subs even better. I just don't want you to be hard on your self if it doesn't sound optimum for the rest of your system. I believe I used 12ga speaker wire. Your best bet would be to go to a installation shop and ask for a 500watt amp kit. It should be only 30 bucks or so and will have all the wires and fuse you will need.
Old 02-22-2009, 03:25 PM
Yes this is going into my El Camino.
I already know it wont sound perfect. Im not looking to win any sound competitions lol. I am just shooting for a little extra.
I dont listen to rap or country of anything like that Im the rare one lol. I like the hardcore metal bands. Like Dead To Fall, Light This City, Darkest Hour, Killswitch Engage. All my music is a very fast beat. Not much in the way of bass aside from the double bass pedal.
So Ill be setting up the amp to push the subs just enough so I feel and hear them but so that the mids are heard the best.
Old 02-22-2009, 04:01 PM
1969NovaSS's Avatar
I was going to warn you about the bass in a cab but since its metal it wont be a problem. If you haven't already a good alternator should be added. It makes a huge difference. My volts used to drop to 12.5 at idle with my lights, fan, and subs hitting. I added a 140a 1 wire and it was the best thing I did. You may also want to look into getting a capacitor. It keeps a constant voltage on your amp to during the voltage drop periods when it does hit.
Old 02-22-2009, 04:21 PM
Funny you mention the alt. I just fully rewired my El Camino and I bought a 140amp alt thinking of the subs
What is a capacitor? What does it do?
Old 02-22-2009, 11:08 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Its kinda like an accumulator in a water system... like a really quickly charging and discharging battery. It stores up bursts of juice so when the amps take a big flow it does two things... 1) it prevents the battery/alternator from taking big voltage variations, and 2) provides more steady voltage to the amps.
For 600w max (probably 200w RMS) I wouldn't worry about a capacitor. I usually don't include a cap until about 600w RMS or more depending on the age and effectiveness of the factory charging components. I'm currently running two 600w max amps in my car with a 140amp alt and I can't see the lights dim at all.
Old 02-22-2009, 11:20 PM
Thank you
Okay cool
Well thank you very much 1969NovaSS for all your help I went and bought the amp kit you had mentioned. With some speaker wire. . . total came to around 40 bucks.
Now I just have to make the time to install everything. I doubt it will be this week tho I have a busy week.
Anyway thank you again for you help
And thank you curtis73 for explaining what a capacitor does and letting me know not to worry about getting one saves me that much more money
holley jet size markzepp820 Engine 3 03-31-2007 10:23 PM
What size wire? gator412 Garage - Tools 7 03-04-2007 09:25 PM
Garage size options 66GMC Garage - Tools 62 02-28-2007 09:32 PM
Is There An Exhaust Size Rule Of thumb To HP Rating? 64nova Engine 10 11-06-2006 11:59 PM
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 01:00 PM
