Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what size carb for 400 sbc
Old 07-05-2004, 03:55 PM
cub cub is offline
I decided to replace the carb on my Camaro. It has a 750 on it now. I took it apart to rebuild it and found that someone had broke some parts. I'm still going to work it to get it right just to learn but I think it needs to be replaced. What should I put back on it 650 or 750 ? It is 400 sbc with 488 lift cam. (supposed to be stroker motor) very high compression 215 psi. turbo 350 trans and 373 gear. What is going to be the best car just to play with on the street? ? Thanks
