Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What size carburetor should I use??
Old 09-20-2010, 07:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by eloc431962
You are correct Cobalt, Seems i got away from what the OP was saying . And he has either wiped a lobe on the cam already or cross wired,
Or out of time. JMO You think maybe he has the valves out of adjustment?
Cole
Cole, I hadn't even thought about the cam lobes- I hope you aren't right- but fear that you may be exactly right, now that I think about it from that prospective.
Good catch, and a vacuum reading will confirm that- or a mis-adjusted valve(s), if the needle has a quick oscillation. If the reading is low and steady, there's hope..
