What size engine is it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2002, 09:33 AM
Post What size engine is it?
I bought a 89 Camaro. The guy I bought it from had a different V-8 put in it. He is not sure if it is a 350 or 305. How can I tell, since it is not the original engine?
Old 12-21-2002, 10:08 AM
Post
Well, there are two markings on the block that can tell you the displacement without having to take the engine apart. The first is on a pad on the front right side of the engine. It is on the block deck that the cylinder head mates to. It should be sticking out past the front of the cylinder head. You will probably have to take the alternator off to see it. The other is on the rear left of the block by the bellhousing mating surface. If you can post either of those numbers we can tell you. I believe in some of the later blocks they actually cast 5.7L or 5.0L on that rear surface by the bellhousing. Also, if he is "not sure", it is probably a 305. Good Luck!
Old 12-22-2002, 05:22 AM
E.T. divided by $ spent= Speed
Post
<a href="http://www.mortec.com" target="_blank">www.mortec.com</a> look up the # on the bellhousing flange on the drivers side.Mortec will tell ya weather its a 350 or 305 and were it came from.Also wile your at it you might wanna pull a valve cover and see what heads its got,mortec lists head #s too(don't bother if its a 305).
Old 12-22-2002, 06:40 AM
Skylark_77_455's Avatar
Post
305's also had a smaller harmonic balancer. I agree with Kevin, check those numbers.
