what size exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2003, 08:58 PM
amc's Avatar
amc amc is offline
Post what size exhaust
i have a ford 302 hot rod rambler that i expect to get 300 to 350 horse out of and around 300 to 350 torque. i'm going to do duel exhaust that will run basicly strait back to flowmasters. what size exhaust tubing should i use? I've been debating over 2", 2 1/2" and 3". what do you think i should use?
Old 01-13-2003, 09:33 PM
46_stvblt's Avatar
Post
I would not go lbigger than 2 1/2 . small block motors, be it chevy or ford seem to run better with 2 1/4 or 2 1/2 inch. That is unless you've got an all out race motor or a blown street motor, then go 3 inch........GlennK
Old 01-14-2003, 01:09 AM
mustang66maniac's Avatar
Ford Freak
Post
I've got a 302 with around 350+ hp and I've got 2 1/2 inch. 3 would be too big, 2 1/4 might take away a bit of performance if you're looking for 350hp.
Old 01-14-2003, 01:38 AM
5.0Towncar's Avatar
Post
I'm run'in 2 1/2 on my 5.0
Old 01-14-2003, 06:38 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I run 3 inch with H pipe on my SBC 400. It may not need that large of exhaust, but it sounds damned good with a set of flowmasters.
Chris
Old 01-14-2003, 09:56 AM
cuda66's Avatar
Post
I had a exhaust system built for my 318 and I have done all the mods like heads huge cam pistons and headers and I am running about 400 to 450 hp and I need a exhaust system built and I asked the guys building it what size pipe should I use. he explained that you want some kind of backpressure and he told me to run 2 1/2. I was asking about the 3 inch and he told me that unless you are running real close to 1000hp or running a desiel motor that i should not even consider that size. my two cents
Old 01-14-2003, 11:49 AM
Post
I agree with 46_stvblt unless you are running a blower or have 1000 ponies stick with 2.5 inches,thats what I run on my SB 350 with around 300+ horses I get good flow and sound from my flowmaster
Old 01-15-2003, 04:27 PM
amc's Avatar
amc amc is offline
Post
thanks a lot. i think i'm going to go with 2 1/2" that shouldn't be too much or too little, once again, thanks for the help.
