what size exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2005, 09:53 PM
what size exhaust
i have a newly rebuilt 350 bored .40 over, 268 lunati voodoo cam with matching lifters, springs, locks, and retainers, , h345np hyperuetectic pistons, 76cc cylinder heads, stock rods, and reground crank ( i don't think that matters), and a double roller timing chain, the specs on the cam are duration at .050 .227/233, the advertised duration is 268/276 the lift is .489/.504 the lobe seperation is 110 and the lobe centerline is 106 , hopefully i will be getting a performer rpm intake manifold, and a 650 holley double pumper, hopefully soon i will bump up the compression to 10:1 and get better flowing heads, anyways what size exhaust should i get, 3" or 2.5" it will be duals going into force mufflers, turned down before the rearend, or i might get it going out in front of the rear tires, it has headers on it also
Old 07-09-2005, 10:39 PM
77z's Avatar
77z 77z is offline
Go big or go home
2.5" should do fine little more backpressure out of it will provided better scavanging too IMO
Regards Mike
77 Z28 496 9 inch
10.23 @ 129
Mad Maggot's Avatar
The lean mean donut machine
You have a very similar engine setup to what I have, and I have a mandrel bent 3" single exhaust (it does wrap over the rear end), with 1-5/8" shorty headers. It goes into a single Pro-Flo muffler (I think this sounds awesome, better than the hollow sounding Flowmasters), and it has dual 2.5" outlets. This setup seems to work great for my engine, as it makes good launching torque and still breathes good at high RPM. If you wanted to go to a dual setup I would go with 2-1/2" pipes, if you want a single exhaust, then go 3". Make sure it is mandrel bent to avoid restrictions, and if you get it installed by a muffler shop, watch very closely what they do when they wrap it around the rear end (if you end up doing this) - don't let them "cheat" and pinch it off, like they initially did to mine!
Old 07-10-2005, 11:03 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
You should be great if you went with dual 2.5 inch pipes
Old 07-10-2005, 11:28 AM
lluciano77's Avatar
I am making tons of power with 2.5" exhausts on my 11:1 400 with Sportsman II heads and a decent cam.
It is better to err to the small side.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
small exhaust diameter up front and big out back?? smlblcks10 Engine 76 01-01-2004 11:24 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
what size exhaust amc Engine 7 01-15-2003 03:27 PM
Exhaust Size 57Chevyman Engine 13 01-09-2002 04:02 AM
