what size exhaust is rite ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2013, 09:33 AM
macrobert68's Avatar
Small Block
Hello everyone .My 406 has a 3000-6800 Rough idle, upper mid-range & top end power cam
10.3 compression flat top pistons
duel welind tunnel ram with 450s
Header Style:Full-length
Header Material:Steel
Header Finish:Silver ceramic coated
Weld-Up:No
Primary Tube Diameter (in):1 5/8 in.
Collector Attachment:3-bolt flange
Collector Diameter:3.000 in.
and im looking a
pypes Stainless steel
Intermediate Pipe Diameter (in):3.000 in.
Tailpipe Diameter (in):3.000 in. Pypes Street Pro Exhaust Systems SGG13S
Is this to big and will it rob power at low speed?
Old 02-23-2013, 09:54 AM
You are going to get a lot of theory, and ideas on this, and some of the advise may actually be true.
But with so much misinfornation existing, and being reproduced by people on the web, the only way to know is to spend lots on time on a chassis dyno, with different exhaust configurations.
The Following User Says Thank You to DanielC For This Useful Post:
macrobert68 (02-23-2013)
Old 02-23-2013, 09:58 AM
Small Block
yea i can understand that .
but i cant remember if the larger the exhaust is for top end speed or low end tork.
Old 02-23-2013, 10:49 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
For your setup I would go with the 3 inch..I don't think you would lose that much on low end and your engine setup is for midrange and top end power..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 02-23-2013, 03:21 PM
Yes, there will be a loss of low-end torque with a larger system (this engine doesn't appear to make much low-end, though). We tend to recommend, for maximum performance, and not necessarily the "sound", stay with 2 1/2" pipe until CID gets up around 500.
Particularly with smaller headers like you have, you need that "step" in the pipe to increase exit velocity. For "driving" (street use), this is important. If it's a dedicated race car that requires an exhaust system, then yes, 3".
BTW, those headers are awefully small for a 7,000 RPM 400. Just my opinion. I'd like to see 1 7/8" units on there. Upper end power would significantly increase. Regardless, this car will need some "stiff" gear to be a decent driver. What heads are they?
Jim
The Following User Says Thank You to Mr. P-Body For This Useful Post:
Old 02-23-2013, 03:38 PM
Small Block
dart shp 72 cc
Old 02-23-2013, 03:43 PM
Small Block
Originally Posted by macrobert68 View Post
dart shp 72 cc
what kind of gear would u use .i was thinking 373 0r 410
Old 02-23-2013, 03:59 PM
Banned
2.5" mandrel bent pipe with x pipe..
from the x junction you have 5" for thet pulse to feed to.. more than anough for a 406
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 02-23-2013, 04:40 PM
Bert, what car? Approximate weight? Trans/converter? More 1/4 mile or 1/8 mile? Significant street driving?
Then I can answer that. As much "detail" as you're willing to share. What style rear axle?
X 2 on the "X" pipe. A lot of our Pontiac guys use Pypes. I've heard good and bad. The X-pipe definitely makes power, though.
Jim
Old 02-23-2013, 07:33 PM
vinniekq2's Avatar
Have you ever seen a race car with mufflers go faster than a similar car with open headers? 3 inch!
also if your engine revs 6500 rpm,your headers are also too small
Old 02-23-2013, 07:37 PM
vinniekq2's Avatar
The rear axle ratio needs to match the purpose of the car. I use a 3.50 gear with 27 1/2 tall tires with a standard. floor it in first or second and the tires break loose.
is it the rite combination mtg Hotrodding Basics 1 08-19-2010 08:17 PM
exhaust size ? knighthawk Engine 7 01-01-2009 02:14 PM
383 main journals this fits rite no machining?? 47chevrolet Engine 5 04-22-2008 02:17 PM
exhaust size help SBC S-10 Engine 2 07-17-2005 12:22 PM
what size exhaust 82c10 Engine 4 07-10-2005 11:28 AM
