What size inlet/outlet for paint booth? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2013, 08:05 PM
jsm1847's Avatar
Finally making my booth. As stated in other posts, I picked up a squirrel cage fan that is direct drive and so I won't be doing a negative pressure and room size is 5x8. The question I have in design is how to make the in/exit holes. Should the exit be smaller than inlet to force a more direct stream (like concentrated), or should they be larger or even the same size? I know it shouldn't be this difficult, but I'd rather measure twice, and cut once....
Thanks for your help in advance!!! I'll be posting pics of my progress....
INLET/OUTLET ID on MOPAR fuel pump? hduff Hotrodding Basics 1 08-19-2013 01:13 PM
Dual Inlet Fuel Pump: One inlet capped ???? Sin7 Engine 8 07-29-2008 02:32 PM
GM caliper inlet size and threads? 58Apache Suspension - Brakes - Steering 6 07-08-2008 05:22 PM
Dual inlet/single outlet Flowmaster SUV 50 Series Muffler for AMC 304 Houman SS '70 Engine 2 12-18-2007 08:14 AM
Can a radiator set up for chevy inlet and outlet be used for a Ford engine? Kruzin Karl Engine 8 12-07-2007 11:12 AM
