what size motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 03:40 PM
what size motor
I bought a model a coupe with a big block in it. says it is a chevy 427. block number is T0211TUA I couldn't find it listed in block codes. Does anyone know what it is.
Old 08-13-2012, 05:02 PM
RWENUTS's Avatar
Get the casting number from behind the drivers side head. That'll help.
Old 08-13-2012, 07:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here is a page w/info on ID'ing the castings. Here's a page on ID'ing various Chevy engines.
I'm not seeing that TUA suffix code. If the suffix is correct that could mean you have a truck engine- they are sometimes left out of the data bases. You'll want to check to see if you have a tall deck block or not before proceeding to build it. If it turns out you have a TD block, here is a thread on a budget build up.
Old 08-14-2012, 11:11 PM
model a motor ID
Thanks for all your help, found out that motor is a 427 truck block . Now I need to try to find LKQ spacer for manifold and special electronic dist. Thanks again . couper
mpg and motor size Dirty Biker Engine 16 07-16-2011 07:41 PM
Should I increase motor mount size sooper Engine 4 12-16-2009 04:34 PM
lost on what size motor i got harley83 Hotrodding Basics 7 02-02-2009 08:02 PM
what size motor for a 32 roadster moldmaker Engine 46 12-07-2005 07:31 PM
still lost on fe motor size. rebelcowboy50 Engine 6 12-05-2005 06:16 PM
