What size is my 1952 chevy rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 02:20 PM
1952 chevy rear end swap?
I've got a 52 chevy coupe, it's got a 54 bel-air 235 and the three speed manual. I'm trying to find information or parts for a rear end upgrade or gear swap to get some decent top speed. Any information or resources would be greatly appriciated. Thanks!
Old 04-01-2007, 09:52 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Your present rear end is probably a 4.11:1 ratio if it is the original and the three speed manual tranny is the original. The powerglide equipped cars used a higher 3.55:1 rear-end drive ratio and you could swap this into your car. A lot cheaper and easier than going to an overdrive tranny.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-02-2007, 03:22 PM
I've got a 52 chevy coupe deluxe, planning on swapping the gears out. It's a 10 bolt pattern, original I beleive. I'ts the three speed manual transmission. Does anyone know what size rear it is so I can track down some parts. Thanks!
Old 04-02-2007, 05:23 PM
Wiki Edits: 31
yep, get a PG rear end, that will get you a 3.55 ratio. if you convert to open drive at any point, a 2nd gen Camero rear is a bolt in, as well as any Tri 5 Chevy is a good fit.
Old 04-02-2007, 06:19 PM
BOBCRMAN@aol.com's Avatar
It's a post war Chevrolet axle. The same till 1955. Good luck finding anything for these rears!
Old 04-02-2007, 06:25 PM
Wiki Edits: 31
there a closed drive ( torque tube ) rear end, so if that's what you have, and your car is an original 3spd car, it would be 4.11's, if it had a PG auto in it originally, 3.55's. you can get new ring and pinions, and bearings from places like EGGE but it's going to cost you. buy a PG rear end if you want higher gears, and have 3spd 4.11's
Old 04-02-2007, 07:27 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I had visions of this thread being another one of those "What kind of car is your wife?" type of deals.
Old 04-02-2007, 08:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
ekubota1,
I merged your two threads on the same basic discussion on your 52 chevy automobile
Old 04-15-2007, 09:28 AM
52 rear end
thanks for all your help !! I guess I'm looking for a pg rear end. Sounds easy so I'm off to the garage before son's break somfin
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
54' chevy rear end gavinpierce Hotrodding Basics 6 02-13-2006 09:31 AM
rear end ratio (85 or newer chevy van) chrisf67 Transmission - Rearend 2 02-27-2003 03:14 PM
