What size of Pro Magnum Hydrulic Roller Comp Cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 11:58 AM
Skunk's Avatar
I need to know what size of Comp Pro Magnum Hydraulic Camshaft to choose for my 383 small block Chevy engine. This cam will be used for street use almost all of the time and it will be going on a 1957 Chevy Truck. So far I have a set of Dart Iron Eagle Cast Iron Platinum Heads with 200cc runners and 72 combustion chambers, Eagle 3.75 Forged Crankshaft, Eagle 5.7 H Beam Connecting Rods, Dart Kool Can Intake, and Speed Pro Forged Pistons. Which Comp Pro Magnum Hydraulic Camshaft and rocker ratio would be the best set up for this engine gentleman? Thanx in advance.
Old 07-02-2005, 01:22 PM
lluciano77's Avatar
Short changed on common sense
Get something with around 230o @ .050". Get the most lift you can with that duration. A 112o lobe sep. will work well.
Old 07-02-2005, 02:18 PM
edge's Avatar
Time is short, are you ready?
Edelbrock retrofit hydraulic roller camshaft #2201 (296/300 Adv. Dur.; 234/238 @ .050; .539”/.548” lift w/1.5s; 112 lsa installed @ 107 intake CL) - ($220 at Summit) ; Howard's retrofit hydraulic roller lifters #91114 - Page 23 on their catalog (About $300 when I bought them a year ago). This cam idles well and has a great powerband, especially in my 383 SBC .
Ed www.edgesz28.com
Old 07-02-2005, 02:39 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Edge, what's that car run?
How'd you get to advertise firefox & a webhost on your site? do they pay you?
Comp cams took care of failing cam TurboS10 Hotrodders' Lounge 12 01-08-2005 07:15 PM
Comp Magnum roller 1.65 for pontiac JedWele Engine 1 11-21-2003 05:12 PM
Comp roller cams reliability in BBC Steam Roller Engine 1 11-02-2003 11:33 AM
roller cam selection Jared Engine 2 10-28-2003 02:27 PM
Pro Magnum Roller Rockers Rad Ray Engine 1 09-28-2003 09:45 AM
