What size rear end do I have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 07:28 AM
My RE came out of a 1991 S-10, 4 x 4, I have got it on jacks and as best as I can tell by turning the wheel and watching my axle, rear it goes around almost exacly 2 x"s with my wheel going around once (1). What size do I have? Also my cover has 10 bolts if that matters! Advise, thanks Dana
Old 09-20-2010, 08:13 AM
big gear head's Avatar
High Performance Rear Ends
It's probably the 7.5 10 bolt. I'm not sure what year they started using the 8.5 in the ZR2 and some other S trucks, but I think all '91s got the 7.5. If you are only turning one wheel and the other wheel is not turning then you must turn the wheel exactly 2 full turns with the other wheel held exactly still. That will give you the gear ratio.
Old 09-20-2010, 10:31 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I am glad you posted that , gearhead . I always wondered how to get it right when only one wheel turns . I knew it wasn't anywhere close on only one revolution of the wheel . I had rolled my T-bucket with both wheels on the ground and counted the revs of the driveline . Now I know the easy way .
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 05:19 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
