Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What size of wire to use?
Old 10-12-2002, 07:27 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I use .035 and have had no problem. The key to not warping panels is to spot weld until the seam is complete. I usually bounce from side to side. I have never done it, but I have read that heating the weld seam with a torch and using a hammer and dolly to flatten the weld will help relieve the warping. You have to have a torch stand and I have not made one to try this.
Chris
