Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What size of wire to use?
Old 10-13-2002, 04:51 PM
Harlequin's Avatar
Harlequin Harlequin is offline
Post
Yes, wire feed welders are migs. The hookup for gas is for a 50/50 mixture of CO2 and Argon. If youíre going to use the gas, youíre going to have to get different wire at your local welding shop. Right now since your not using gas your going to be using a wire called Intersheild(aka flux core). The flux creates a slag on the weld that has to be removed. When using the copper wire with gas there is no slag that is left behind, hence, a cleaner weld. Hopes this helps! :p
