What socket for Ford 9" Pinion nut? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2009, 12:17 PM
Anyone happen to know off the top of their head what socket is needed for the pinion nut on a ford nine inch?
I'm switching to a 1350 yoke and need to get that bugger off of there.
Thanks a lot.
Old 01-14-2009, 12:22 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
not sure but a large one for sure,
I am sure you can figure it out
if not stop working on cars cause, it only gets more confusing for here ...
obtw: channel locks not an option
Old 01-14-2009, 12:28 PM
Just received my new driveshaft with the new pinion yoke today and was hoping to stop by the hardware store after work to get the correct socket without having to go home first.
Just thought someone might be able to help out.
Old 01-14-2009, 12:31 PM
pepi's Avatar
1 1/16 should do it
just a tip just after you break the nut loose and I mean exactly at that point , find a way to mark and count the turns until the nut comes off, you will need to re-tighten it exactly the same amount of turns, at that point stake the nut to hold in place, do not attempt to re torque cause you could crush the crush ring and loose the pinion too ring gear clearance
Old 01-14-2009, 12:54 PM
prostreet6t9's Avatar
Differential/Driveline
Yes it is a 1 1/16 socket. Counting the turns of the nut is NOT the correct way to do a crush sleeve.
No need to stake the nut on a 9", Use red lock tight.
Old 01-14-2009, 01:03 PM
pepi's Avatar
if replacing the crush sleeve or installing a new gear you are correct but, he is just replacing the yoke and that is a good way NOT to change the clearances of the gear counting the turns...
red lock tight does not work real well on dirty or oily surfaces
Old 01-14-2009, 01:08 PM
Thanks guys. Forgot to mention i am using a solid spacer instead of a crush sleeve.
Old 01-14-2009, 03:01 PM
I do it all the time without changing any clearances. As far as dirty surfaces,That is what brake cleaner is for.Pull the yoke off,Spray a couple squirts on the threads and Wa la! Clean threads!
Old 01-14-2009, 04:35 PM
tnsmith10's Avatar
when will it rain???
not to mention, u can change yokes all you want, but if they dont measure exactly the same, what good is counting threads gonna do in the 1st place???
i agree with prostreet, it would be hard pressed to believe just because someone needs a bit of info that they are that naieve to not clean the threads on the pinion for re-assembly. and besides putting locktite on, it seems to me that when buying a new yoke that from my experience that it comes with a new washer and locking nut anyways...
Old 01-14-2009, 05:46 PM
302 Z28's Avatar
Crush sleeve does not determine pinion depth, that is the purpose of the shims. All a crush sleeve does is pre load the pinion bearings.
Vince
Old 01-14-2009, 06:12 PM
Vince
BINGO! You are so correct!
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
Need Help Installing Ring & Pinion in 9" Ford S10 Racer Transmission - Rearend 5 04-21-2008 01:27 AM
pinion nut welded to pinion GMR Transmission - Rearend 7 02-21-2007 08:47 PM
Help Removing Pinion Gear Nut on GM 10-Bolt leejoy Transmission - Rearend 13 11-11-2006 08:36 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
