What spark plug should I run??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2005, 02:47 PM
Ratoflic's Avatar
Big cubic inches small Chevy!
Hi everybody!
I have a big block chevy, I heard I have to run cold spark plug, Right now, I run AC Delco R44T, is that the right spark plug??? Or I have to buy another like NGK V groove or something else...
My head are GM Iron 353049
Any advice.
Stephane
Chevy man forever!
Old 07-29-2005, 08:52 PM
New Member
Stephane when i was running stock cars chevy in fact i used autolite spark plugs cant beat them for performance i know sounds weird but they work. They have a good temp range too.
Old 07-29-2005, 09:29 PM
coldknock's Avatar
Try Autolite AP145's. Make sure the ignition is up to snuff. Cold plugs don't work well with weak ignitions.
Larry
Old 07-30-2005, 10:41 PM
Ratoflic's Avatar
weak ignition
Larry
Hi Larry, in fact, I really don't have a weak ignition, I have a DUI (davis unified ignition) they said I can gap spark plug to 55 thousand.
I heard I have to used NGK V groove UR5 spark plug or R44t (AC DELCO)..I never heard about autolite AP145...are they common???
Stephane
Chevy man forever!
Old 05-24-2008, 08:20 PM
spark pluggs
The only reason to go down a heat range or up a heat range or vise versa is if you pull your pluggs out and theirs ash build up or detonation. I suggest going with a very basic autolite copper plugg. Copper is the best conducter in the world besides gold of course. So I would just throw a cheap set of autolite coppers at it. Now the downside to running a copper plugg is you'll be replaceing them more frequently(I do mine every 15,000).
Old 05-24-2008, 09:57 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Hi Stephane, I have seen so many drivability problems with NGK V groove spark plugs don't use them. AC R44t plugs are OK to use. I recommend Autolite APP145 spark plugs gapped at .045 thousands. These will give you a good burning combustion throughout all temperature ranges, and longevity is a plus.
Stephen
Old 05-25-2008, 08:18 PM
ratpackin's Avatar
Last journal entry: old setup pic-
I don't have a heat range for you- though I was running R44 plugs fine a few years back. But it might be worth your time to check out E3 plugs. I've had a couple of guys I trust who run both street and strip recommend them to me.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 08:25 PM
Spark Plug expert needed :-) x007 Engine 6 09-07-2004 06:34 AM
Pictures of spark plug readings ATMRacerTX Engine 2 12-11-2003 07:59 PM
Smashed in spark plug tip (internally)and porcelain Hookedontrucks Engine 7 09-14-2003 06:48 AM
