What spec.to set front end. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2002, 07:16 AM
Pro Street's Avatar
Go Pokes!
Question What spec.to set front end.
I just bought a Pro Street 1983 Chevy S-10 full tube chassis.It has 4-link rear with coil overs and MustangII front suspension with rack and pinion.It does not drive very well on the highway.
What should the front end spec.be on this set up?
Old 11-10-2002, 08:19 AM
4 Jaw Chuck's Avatar
Post
Anywhere from 0 to 1/8" toe-in on each side will get you started.
Outlawed tunes from outlawed pipes
Old 11-10-2002, 10:06 AM
SJFast's Avatar
Post
If it's wandering on the highway increase the caster. Is the rearend square in the thing ? Is the front end square with the rearend ?
Old 11-10-2002, 01:08 PM
dmorris1200's Avatar
doesn't play well with others
Post
Agree with everything so far, also try to get camber as close to 0 degrees as possible maybe just a bit negative camber with a little positive toe-in.
Old 11-10-2002, 04:59 PM
Pro Street's Avatar
Go Pokes!
Thumbs up
Thanks guys!
What about caster?
