What are the Specifications on a '98 Firebire Rear Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2011, 11:59 AM
I'm considering a firebire rear axle for my 37 Plymouth. The gear ratio on it is 3.42 and it is a posi rear. What motor/trans was typically combined with this axle at the factory? What is the width of the assembly from wheel hub to hub? What is the dimension from the center of the axle to the center of the universal yoke hub? These are important to me as I currently have a Camero corporate axle on the car and I want to be sure the driveshaft will still fit correctly.
rear axle k.c. Suspension - Brakes - Steering 3 06-19-2009 06:03 PM
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 08:25 PM
rear axle murfeey General Rodding Tech 1 05-21-2005 10:56 PM
rear axle sbc350 Transmission - Rearend 4 03-31-2004 12:33 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
