What speedo gear do I need?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 11:33 PM
MOTOR HEAD's Avatar
Born to Wrench
Hey guys , I'm returning my 79 T/A to the original automatic transmission state & have a speedo gear issue I need to resolve. I am putting a TH-350 back in the car ( from the Wife's T/A...now I owe her one ) but I have purchased a new set of 17x9 wheels for the car also , the tire size ( I'm pretty sure I'm going to use unless I can go a little wider and a tad taller ) is 245 x 45 x 17. The rear end ratio is 3.73. Are the auto gears color coded like the manual gears? I used a RED gear with the 4-speed and original 15" tires. I don't need any speeding tickets!!! Thanks ahead for any input.
Old 05-11-2009, 11:54 PM
Here's a site to help.
http://moldyrabbit.com/liquid/speedo_gear.html
Old 05-12-2009, 12:08 AM
MOTOR HEAD's Avatar
Born to Wrench
Originally Posted by crownver
Thanks Crownver!!
Old 05-12-2009, 05:32 AM
SSedan64's Avatar
Another Speedo Gear Chart. > http://novaresource.org/speedo.htm
Old 05-12-2009, 11:15 PM
MOTOR HEAD's Avatar
Born to Wrench
Thanks SSedan64!!
Old 05-13-2009, 11:52 PM
fast68's Avatar
likes chevy trucks & boobies
not sure if you knew or not already but if you wan to check real quick to see how far off your speedo is, or just to check it, run the car at 60mph on the dot and use a stop watch to time how llong it takes to get from one mile marker to the next
if its off by only a couple seconds then i wouldnt worry about it,
as that is a couple mph difference from dead-on
no biggie really.
good luck!
Old 05-14-2009, 12:04 AM
MOTOR HEAD's Avatar
Born to Wrench
no biggie really.
good luck!
Thanks Fast68!!
TH350 drive gear replacement dawg Transmission - Rearend 8 04-28-2007 10:07 AM
THM speedo gear seal mhamilton Transmission - Rearend 4 02-19-2006 11:36 AM
speedo gear? f8lpony Transmission - Rearend 2 01-30-2005 04:39 PM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 04:56 PM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 04:03 AM
