What Spray Gun Do You Use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2010, 12:50 PM
I'm curious on what people are spraying with, and for what application (primer, base, clear)
I use a 1.5 $30 primer gun from Northern Hydraulics
I have a 1.3 Sata 98 that sits because there is a air obstruction (but was my metallic base gun).
I have a 1.5 Snap On (Sharpe) Excalibur I bought in a pinch, and regretted very much, also has internal air obstruction.
I have 2 Sharpe FX200 conventional guns ready to go as backups in case on of my guns fail for whatever reason in the middle of the paint job, they spray clear nicely, but they love to make over spray.
I have a 1.4 Sharpe FX300 I use as my main gun for base and clear, the cup lids are horrible, they shrink and break, I went through 3 of them in a month.
So I switch to the 3M PPS cup system, and I'll never looked back.
I have a few oddball touch up guns as well.
Old 01-07-2010, 04:28 PM
Iwata LPH400 1.3 for clear, purple cap for base. (About to purchase a w400 just for clear.)
Sata NR2000 1.4 For final prime sessions (wetsand) and epoxy/sealer. Back-up basecoat.
Sata KLC-P 2.5 for polyester primers, with a 2.0 conversion (tip, needle, cap) for urethane primers.
Sata Minijet for spot/touchup.
All are pps.
I went through so many of those cheap $30 guns for primer I decided to step up with the sata and never looked back. Thing is 3+ years old and still spraying like a champ.
Old 01-07-2010, 04:45 PM
milo's Avatar
point on positive
I use the same one gun with a 14 tip for everything...still
It's a German gun.. http://www.hotrodders.com/gallery/sh...p?ppuser=13824
Old 01-07-2010, 04:54 PM
Cutterbond, i have a Iwata 400, and the cap for clear. Disposable hf for primer. Now i have to learn how to paint with it.
Old 01-07-2010, 06:44 PM
Countilaw's Avatar
Cox Custom Cars
It's not the gun that makes a painter!!!!
I use a Devilbiss FL3, for base coat, clear, most everything,
I have a $9.95 HF siphon gun for primer.
and I have some touch up guns. But they are not for touching up, just for spraying small items.
So you can spend a million dollars for a Sata, or whatever, it still doesn't make you a painter.
Any old timer will tell you that.
Kids !!!!!!
Frank Cox
Cox Custom Cars
Cox Custom Cars
Old 01-07-2010, 07:56 PM
smithkustoms's Avatar
Tekna (devilbiss): clearcoat only
Devilbiss CVi : base/single stage metallics
Binks M1-G: Base/single stage
Sharpe 1.7 : razor. Primer (best primer gun ive ever used)
SATA SL 90 : old Primer replaced by razor
Binks 95G : Old old primer gun replaced by sata 90 rarely used now.
Guns don't make the painter. But they do have a story to tell....
I use devilbiss type guns for the ease of replacement parts, and because they don't have the fan control on the side like the sata guns do. I hate that. Its a flaw in my painting skills. I rest my pointer finger where the sata fan control knob sets. using a sata gun I turn the knob wile spraying
Time to Buy a Spray Gun Fast Eddie D Body - Exterior 14 02-05-2009 10:00 PM
Why is is bad to spray primer through a exspensive gun? hutcholdschool Body - Exterior 12 01-31-2009 09:19 AM
Need a good spray gun for spraying metallic base camaro freak Body - Exterior 1 04-18-2006 05:26 AM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
ADVICE ON PURCHASING A HVLP SPRAY GUN STATUTORY GRAPE Body - Exterior 38 05-27-2004 11:30 AM
