what spring and shocks for 69 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2005, 04:59 AM
I am rebuilding my 69, I would like to keep the ride height for clearance. all the springs I see are for lowering the car. any suggestions for spring and shocks. also what size wheels fit well (and tires). I am putting a 510 HP small block in. thanks
Old 08-30-2005, 06:06 AM
302 Z28's Avatar
You can get replacement springs from various sources like Yearone http://www.yearone.com/ for instance. You can safely put 15" x 7" rims with 245 x 60 series tires without changing the ride height. Anything bigger will rub when turning.
Vince
Rear suspension spring helpers Meteor Suspension - Brakes - Steering 2 09-19-2004 11:24 AM
Spring Vs Spindle in S-10 Andrew7dg Suspension - Brakes - Steering 13 02-18-2004 05:19 PM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 08:39 PM
is there a better way to get rear lift than spring expanders? IHAVECHEVYPARTS Suspension - Brakes - Steering 0 11-14-2002 08:50 PM
rear shocks beetle9 Suspension - Brakes - Steering 2 03-02-2002 06:44 AM
