What springs and weights should I run - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2010, 05:56 PM
I need real hot rodder advice I bought a used hei after mine cavved.. I have a 355sbc, vortec heads stock, crane cam 216 / 216 .454/.454 max 5500 rpm sweet spot 2500-3000 th400 tranny with 3200 stall (stals less with my setup bout 2500 or less ) ford 9 " 4:10 gears spooler by strange no power brakes or steering. I noticed the distributor I have has the lighteset springs I have ever seen and lightweights What would you mild street racers use in a setup like mine I have timing at 12 before tdc 600 vfm Edelbroxk (man I love my new carb) Any advice would be great.. I was going to put the stock weights from a 305 camaro with the lighter springs to start and see what happpens,,, ALSO if anyone thinks I should run ported vacuum I need advice there too THANX
Old 08-20-2010, 06:15 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
springs
I've noticed the aftermarket kits have lighter weights and the light springs probably are a reasonable match; maybe a bit quick.
It would be quicker and good this thread, to put a timing light on it, and a remote tach or someone inside. Record the deg advance at every RPM until it's maxed out. Then post the results. That gets us in on it!!
Old 08-20-2010, 07:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have not had good results using the aftermarket weights and cam. If it were me, I would replace the weights w/an OEM set of weights and cam. Be sure to orientate the cam and weights correctly- you can install them "upside down" if you're not careful. The wear marks on the original weights from a Chevy HEI will show you how they go, the cam should be orientated so that it opens the weights as they should be.
Then w/the original weights in the distributor, install a set of medium springs and see what the results are. The HEI distributor is able to provide a lot of mechanical advance, but it's the weights that say just how much of this potential advance is actually available. Different weights/cams provide differing amounts of advance.
You can make a temporary timing tape to let you see how much total mechanical timing you have available, w/o needing a dial back timing light, and to set the total timing, etc..
Weights move freely but distributor shaft wont spin Chevy21 Engine 2 11-01-2007 05:07 PM
springs weights tweaked Transmission - Rearend 1 09-10-2007 09:32 PM
New distributor...weights sticking? redneckgmc Engine 3 01-27-2005 08:21 AM
idel speed affect timing?? smlblcks10 Engine 3 04-14-2004 05:15 PM
Mallory Uni-lite advance weight springs....? nastynova Engine 7 07-28-2003 09:45 PM
