what stall convertar, and tranny should i use? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-04-2011, 10:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Regardless, the amount of slip is not excessive at light throttle and/or cruise speeds w/a 3500 RPM stall speed TC- and that's where you are mistaken.
  #17 (permalink)
Old 02-04-2011, 10:54 PM
ericnova72's Avatar
More for Less Racer
You are confusing stall speed(stator sprag locked, stator fins redirecting fluid at maximum efficiency, multiplying torque at the converter designs maximum rate(usually between 1.7 and 2.2 to 1 in most performance converters) with the speed at which the converter "couples"(stator sprag is no longer locked and converters driven turbine has matched (or nearly matched, never is 100% unless it is a lock-up clutch equipped converter) the drive turbine speed at lower than peak loads and power inputs.
  #18 (permalink)
Old 02-05-2011, 03:03 PM
1971BB427's Avatar
I guess from your replies that you assume I've not been around cars or trannies since 1969. I give up, you're way too smart for me.
  #19 (permalink)
Old 02-05-2011, 03:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jeffery wells
o.k. im in the process of building a 400hp 350 to put in my 1980 chevy malibu, it has a thumper cam, performer intake manifold, 650cfm carb, and i just had the stock vortec heads machined out.
i have a turbo 350 transmition and i dont know if i should have a shift kit instaled or get a beefier tranny all together, and my other problem is i dont know what stall converter i should use, i have access to a tci 2400, but i dont know if it will give me the launch im going for, im really building this as an every day driver, but, there are so many imports around here that i cant help but run em from light to light, anyone with any sugestions would help.
I would question why you want to use a thumper cam- there are far better cams that make more power than those "bark w/o much bite" cams.
I know- you want the "sound", right?
AFA a "Performer" intake, if you add "RPM" to that, you'll have something worthy of your time and trouble.
Choose the torque converter to compliment the cam/engine's powerband. Often a "tight 10 inch" TC works well w/a performance SBC build, but this is a generalization- the exact TC will depend on other things besides the engine, like weight, use, traction, chassis set-up, etc. Use a tranny cooler.
A TH350 w/a solid rebuild- with a shift kit- will suffice- it will break the 7-1/2" diff way before the transmission breaks.
Turbo tranny w/small stall converter Mitchman Transmission - Rearend 2 11-16-2010 06:00 AM
stall...do I need one? cutthroatkid Transmission - Rearend 3 08-24-2009 10:42 AM
High stall or low stall neverending Transmission - Rearend 12 02-26-2007 08:28 AM
TH350 tranny with 2500 stall not stalling why? 1badFn68 Transmission - Rearend 3 11-16-2006 08:47 AM
Tranny fluid and stall converter Questions 406chevelle Transmission - Rearend 5 06-09-2004 04:28 PM
