what stall convertar, and tranny should i use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2011, 04:04 PM
jeffery wells's Avatar
o.k. im in the process of building a 400hp 350 to put in my 1980 chevy malibu, it has a thumper cam, performer intake manifold, 650cfm carb, and i just had the stock vortec heads machined out.
i have a turbo 350 transmition and i dont know if i should have a shift kit instaled or get a beefier tranny all together, and my other problem is i dont know what stall converter i should use, i have access to a tci 2400, but i dont know if it will give me the launch im going for, im really building this as an every day driver, but, there are so many imports around here that i cant help but run em from light to light, anyone with any sugestions would help.
Old 01-31-2011, 06:58 PM
mud.man.rj's Avatar
stall what WHAT
2500 stall will work fairly good for daily driving with some running it, but to run it harder with more rpm (hope you changed valve springs for the cam) aka racing imports you need a good cam a better intake like an RPM at least and a half decent set of gears so you could better utilize the 3000 stall. A stock t 350 trans with a shift kit holds up suprising well to 400 hp a bit at a time not all day every day. I have ported some performer intakes and ran them with 2500 stalls with the same heads and they ran nice down low to about 5200 rpm but for more I would change up intake and stall to run a bit higher shift point. Hope some of this helps.
Old 01-31-2011, 07:25 PM
I agree with mud.man.rj the th350 should be good. Just a side question. Do you still have the stock rear end in in? Just curious. I have the same car but mine is Pontiac's version... and a wagon 1980 Grand Lemans Safari Wagon.
Old 02-01-2011, 09:12 AM
1971BB427's Avatar
Need more info to determine stall speed. Just slapping a 2500 in wont work if your rearend gear ratio isn't low enough. With a 3:42 gear ratio you'll be running around 2300 at 55 mph so it will never be fully locked up at cruising speed. If it's even higher geared you're in worse trouble!
I'm running a 2200 stall in my 71 Camaro and it works just great with my 3:42 rear gears.
The 10 bolt will easily handle the 400 hp you're going for. I run a 8.5" 10 bolt in mine with a built 427 and it's held up well for the last 30 yrs. since I put it together.
Old 02-02-2011, 08:09 AM
1971BB427's Avatar
Originally Posted by F-BIRD'88
Get a 10" 3500 stall and 4.10's. A Transgo shift kit will get it done.
Malibu Traction: Air lift rear air bags (drag bags)
+ rear lower control arm relocation brackets (UMI, Spohn)
Mickey Thompson ET street radials.
Get a driveshaft safety loop.
The thumpr cam wants a modified distributor advance curve.
The typical stock out the box curve will not work well.
3500 stall? You're joking right? When will he ever get it to lock up, unless he's cruising down the freeway? And with 4.10 gears he wont be doing much cruising.
Old 02-02-2011, 10:25 AM
well, i don't plan on having it on many highways, just in town running really, it's got the stock rear end with 4:11 gears. there is only one highway it will be on and that's only for about 4 min to my brother & laws house. if i put the 2400 stall then i should go with the performer rpm intake? wouldn't i have to run a higher cfm carb to? like 700?
Old 02-02-2011, 10:32 AM
sorry mud-man, i forgot to include that i have replaced the valve springs, but just to the double valve springs, nothing special, and the distributor is MSD. did i screw up or is that going to work alright.
Old 02-02-2011, 10:57 AM
dang, another thing i forgot to mention is the cam, it's a thumper. no special heads just machined the stock heads, mechanical fuel pump, electric fan, 6qt oil pan, high torque starter, high flow oil pump, im ordering the performer rpm intake and the edelbrock performer series 650cfm zinc plated 4barrel, im wanting to get the street scoop 2 but that will be down the road, i have 3 kids that live with me, one on the way, and 2 that don't live with me, my army check only pays so much since im only in the reserves, and my children will always come before my toys, so getting this car down the road will take some time, but it will get done someday, and hopefully before next spring.
Old 02-02-2011, 04:49 PM
The 10" 3500 rpm converter will perform well. You do not get the full effect of the converter unless you apply sudden amouts of torque loads like half throttle all at once or more. It will do fine with a good set of matched gears.
Old 02-02-2011, 08:45 PM
Hey, Just as a side question, sort of off topic, but when you put the 4.11's in your rear did you upgrade the rest of the housing internals? axles, c-clip eliminators? I know those stock little 7.5" rear ends don't hold up well to power.
Old 02-02-2011, 09:30 PM
mud.man.rj's Avatar
what stal again
You started out as a daily driver, now your up to a street ripper with rpm, it gets tiring trying to keep a converter locked up if you don't it produces heat. So now you REALLY want to build a bit of a street racer and cruise it some. So go 4:10 ratio a 750 carb/ rpm intake and realistically a 3000 stall and you can cruise slow with it locked up with a bit of rpm or blast it and be all around good. I know for myself I would use this setup but also a 700r4 so I could have a lower 1st gear for better bottom end and 4th for any highway with some saving the engine and gas mileage. Each to their own though, lots of opinions.
Old 02-04-2011, 05:08 PM
well, thank you all for trying to get me on the right track, i would really have a nice motor with no attitude if it weren't for you guys, so i think im going to go with a little of what everyone is saying and lean more towards what mudman sead, i think it sounds like a 3000 would be great. ooh, and sorry, i don't know about the internals in the rear end, other then the fact that's it got 4:11's, i had my ex step dad do it for me before he left, so honestly i don't even know if he did it right, the car has been parked since then, sorry i couldn't help yea out. sounds like it's going to be a pretty mean little Malibu, if i can ever find my digital camera i'll take some pic's, if i cant find it i'll just get a new one when i get my taxes. and once again, thanks everyone.
Old 02-04-2011, 05:28 PM
1971BB427's Avatar
No I`m not kidding. High stall converters `cruise `very well on the hiway when matched to the right rear gears.
The converter coupling at part throttle while `cruising`is quite good in fact.
One of the biggest mistakes many people make is not picking a converter and gear combo to match the engines power band and assuming that a high stall or gear will be evil.
If you want to get the power of a `thumpr cam`and go fast you need to the correct gears and converter to use the power.
When tuned correctly this type of setup is actually quite good on gas.
many people combine a high stall with the wrong gear and then complain about slippage or....
Well your info seems to contradict yourself. You say a high stall is good, but then too high will cause slippage. That was exactly my reason for questioning a 3500 stall. That converter will only be locked up fully and not cause slippage when he's on the freeway unless he constantly keeps it above 3500 rpm around town. Having a converter with a stall speed that's higher than what you will normally use driving around town will only create excess heat, and gas mileage will be grossly affected by hainv to use lower range in the tranny to keep it above 3500 to lock it up all the time.
Old 02-04-2011, 09:36 PM
ericnova72's Avatar
More for Less Racer
Mistake is thinking it is like a slipper clutch in a go kart, that it has to rev at least 3500 to do anything or lock up. They don't work like that. A 3500rpm stall converter is only 3500 stall under WOT, at lower throttle openings the converter will couple up at a much lower rpm. They do not slip like crazy at cruise speeds, that is a myth perpetuated by the car magazine idiots.
I've cruised a 4500 and 5200 stall converters around on the street with absolutely no problems, and so have 1000's of others. Doesn't slip badly or make a ton of heat in town at all...unless you are leaving every single intersection like it was the final round at the US Nationals.
I agree F-Bird is exactly right, I feel the same way. 95% of all rodders buy too low a stall based on this false fear of it "slipping like crazy if my rpm is too low". This is one of the most common performance mistakes I see.
Old 02-04-2011, 10:37 PM
1971BB427's Avatar
I'm not mistaking a torque converter for a clutch. What a torque converter does was thorughly covered way back in 1969 when I was in GM training school. I do understand what a torque converter is, and it's name truly explains what it does. It transfers engine torque to the drive components.
If the torque converter has too high a stall speed it is inefficeient, and never "catches up" up to engine speed. The stall speed of the torque converter is the speed when 100% of the engine's torque is transferred tothe transmission, and the engine and torque converter are going the same speed. Prior to that time the two are going at different speeds and the torque converter doesn't fully transfer torque, and it builds excess heat, which is cooled through an external cooler.
I'm sure you know some of this, but hopefully some will get a clearer picture of what a torque converter is and does.
Turbo tranny w/small stall converter Mitchman Transmission - Rearend 2 11-16-2010 06:00 AM
stall...do I need one? cutthroatkid Transmission - Rearend 3 08-24-2009 10:42 AM
High stall or low stall neverending Transmission - Rearend 12 02-26-2007 08:28 AM
TH350 tranny with 2500 stall not stalling why? 1badFn68 Transmission - Rearend 3 11-16-2006 08:47 AM
Tranny fluid and stall converter Questions 406chevelle Transmission - Rearend 5 06-09-2004 04:28 PM
