What is the standard deck clearance on a SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 08:21 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
What is the standard deck clearance on a SBC with:
-stock crank (3.48" stroke)
-stock rods (5.7")
-flat top pistons
Old 01-06-2011, 08:38 PM
Check your spark plug gaps
stock deck height of a sbc is 9.025, to get total height of your rotating assembly take the crank 3.48 divided by 2 (1.74), add 5.703 for the rod length (7.443), then add the compression distance of your piston to that and that will be your deck clearance
Old 01-06-2011, 09:08 PM
King of my Man-cave.
-stock rods (5.7")
-flat top pistons
As mentioned above, the deck spec. is 9.025", but some might be 9.030" or more. Measuring it is the only real way to be sure for your particular block. Also, pistons can vary in compression height. Performance pistons generally have factory spec. compression height, while aftermarket, stock-type replacement pistons are usually decked .020" to compensate for overbore, head and/or deck milling, etc.
tom
Old 01-07-2011, 05:37 PM
how would one go about measuring for deck height to check?
Old 01-08-2011, 05:44 AM
SSedan64's Avatar
http://image.chevyhiperformance.com/...mage_large.jpg
http://www.chevyhiperformance.com/te.../photo_08.html
Measure parallel with the Piston Pin so you don't measure any Piston rock.
A Straight Edge and Feeler Gauges or if you want fancy a Piston Stop with a Dial Indicator can be used.
http://www.summitracing.com/parts/SUM-900188/
http://www.summitracing.com/parts/SUM-900060/
There's one in the center of this Pic>> http://image.chevyhiperformance.com/...mage_large.jpg the Dial Caliper is leaning against it.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
39 standard Jim Rud Hotrodding Basics 0 11-22-2009 12:28 PM
steel shim gaskets / piston to deck clearance 396 fire_hawk108 Engine 2 07-15-2008 04:28 PM
Question about measuring deck clearance v8hed Engine 3 06-15-2008 04:37 PM
Piston to deck clearance, and compression BourgD Engine 24 05-13-2008 06:36 AM
Deck Clearance-SBC 350 Mr. Goodwrench Motor? acr Engine 7 04-20-2005 04:11 PM
