what are the steps to replacing a heads gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 01:33 PM
New Member
what are the steps to replacing a head gasket
what are the steps to replacing a heads gasket on a 95 Dodge Caravan 4cyl. engine anyway? and are there bearings that have to be replaced?
Old 03-19-2005, 01:43 PM
predator carb guru's Avatar
Mark Goulette
if you want to do it yourself, go to the parts store and the the HAYNES (not chilton) manual for your car. it's the best going and will guide you step by step with instructions and pics.
Old 03-19-2005, 01:45 PM
New Member
thanks
thank you guru ill do that
Old 03-19-2005, 01:48 PM
New Member
alaska
i also lived in alaska guru .... anchorage, kenai,.....
Old 03-19-2005, 02:03 PM
If you want a really good manual, the best investment you can make is in a Factory Service Manual (FSM). These can be bought from Chrysler through Dyment Distribution. No parts store manual comes close.
Dyment Distribution Services
P.O. Box 360450
Strongsville, OH 44136
(800) 348-4696
(216) 572-7240
fax: (216) 572-0815
Old 03-19-2005, 04:58 PM
New Member
ok
i took a motocycle engine apart once andput the thing back together and it was cake cant be too bad
Old 03-19-2005, 06:06 PM
Siggy_Freud's Avatar
Getting through the FI and wiring can be a bit tricky. Haynes manual will work. A service manual might be of more help but if your mechanically inclined at all you should be okay.
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 12:58 PM
292 Turbo Heads sb72elcamino350 Engine 1 08-16-2004 06:34 PM
printoseal gasket question. TVR383 Engine 2 03-20-2004 02:46 PM
replacing cylinder heads frank brooks Engine 1 06-02-2003 08:54 AM
L98 IROC/TA/Formula heads? dirtlmfan Engine 2 02-17-2003 12:02 PM
