what is a stock stall converter for a 350 turbo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2004, 03:45 PM
batman09's Avatar
CLICK ON MY AVATAR
what is a stock stall converter for a 350 turbo?Is it 2000,2500??Thanks bm
Old 12-04-2004, 05:41 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Well thats a little high. Depending on what vehicle the TH350 came in the stall speed will vary. But just ball parking it, around 1500 rpms.
Old 12-04-2004, 05:44 PM
batman09's Avatar
CLICK ON MY AVATAR
its in my 67 nova.Is there a way to find out what it has in it?thanks bm
Old 12-04-2004, 05:58 PM
Ghetto Jet's Avatar
I see. Well surely that transmission isn't sporting the factory torque converter anymore. I suppose you could try to find a brand name or #'s on the converter that could give you a place to start researching. But it's really more trouble than it's worth. Especially since you'll probably get an answer like 1500-1700 rpms.
Old 12-04-2004, 06:01 PM
batman09's Avatar
CLICK ON MY AVATAR
i'm doing research on buying a new cam.I need this info.any ideas?bm
Old 12-04-2004, 06:09 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Batman09,
All the info I have found says, if the converter is stock , it should be 1800.
AngliaBob
Old 12-05-2004, 05:19 PM
I have a 350 turbo from a stock 66 Chevelle behind the stock 283 that came from the same donor car (it is in my 28 rat rod). The stall is 1,200 rpm.
