What is this stuff?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2006, 03:57 PM
modas's Avatar
Dazed and Confused
Last journal entry: Trunk Part 21
Hi Guys -
I sandblasted some parts from a donor car (front cowl pieces and rocker pieces). Most of the parts had some pretty deep pitting, but cleaned up nicely. However, there is some black "crud" still on the parts. The stuff seems to be unaffected by the sandblast and is really, really hard. I can't even scratch it with an awl.
I'm assuming this is rust, but I've never seen anything like it. Should I run some naval jelly (I think that is the name of the stuff, the pink stuff ) over these parts before putting 2k epoxy on it?
Any help is appreciated!
Joe
Old 05-08-2006, 05:52 PM
steve t's Avatar
ex biker, now hotrodder
maybe road tar
Old 05-09-2006, 07:34 AM
modas's Avatar
Dazed and Confused
Originally Posted by steve t
maybe road tar
I don't think so. The stuff is so hard, I can't scratch it. Not to mention that its on the inside surfaces of the pieces, not in direct access to the outside. Its really strange. I was going to take pictures of it last night, but I had to go to the town board meeting. Some fool wants to put an asphault plant in my back yard.
Using the naval jelly on clean steel doesn't have any adverse affects does it? I've never actually used the stuff before.
Thanks for the help!
Joe
Old 05-09-2006, 08:40 AM
roger1's Avatar
It's rust.
Bead blasting doesn't work real well on this kind of heavy rust. You need some aluminum oxide or crushed glass to blast that kind of rust off.
Or, hit it with a wire wheel after using naval jelly. Do this combo over and over until it is gone. It may take many iterations.
Put your wire wheel on a drill that reverses direction and reverse it often. The wire wheel is more effective this way.
Old 05-10-2006, 09:26 AM
modas, i don't know what you are working on, but that black stuff maybe old timy under coating. sand blasting doesn't have any affect on it. your best bet is the same as with heavy rust. a wire brush and time, it will come off.
a brush on a small grinder works best. good luck.
More Cool Hand-made stuff Weimer Hotrodders' Lounge 10 03-05-2009 07:34 PM
Good stuff to sell on ebay? FASTCHEVY Hotrodders' Lounge 10 03-19-2004 04:33 PM
WooHoo!!! New stuff! Weimer Hotrodders' Lounge 7 02-05-2004 02:58 PM
Some Good Stuff Kevin45 Hotrodders' Lounge 1 01-31-2004 10:43 AM
builders show yer stuff carcrazy1 Hotrodders' Lounge 6 09-17-2003 11:19 PM
