Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What suspension for a 32 ford coupe?
  #28 (permalink)
Old 08-30-2011, 05:04 PM
Centerline Centerline is offline
Wiki Edits: 49
Well, I'll give you a little incentive.... mine moved under its own power for the first time today. Still chasing some minor brake line leaks and have to adjust the clutch a little but its finally movable under its own power.
Centerline
HotRodsAndHemis.com
Top ten reasons racing is better then sex:
1)You're expected to burn rubber, 2) It's OK to be a spectator, 3) There is a pit crew to help you out, 4) The faster you are the better you are, 5) It can last for several hours, 6) It's acceptable to tailgate, 7) You're supposed to finish first, 8) Earplugs are OK to drown out noise, 9) You don't have to kiss the race car, and 10) You get a trophy when your done!
