Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what are the symptoms of having the wrong #1 cylinder
Old 06-20-2012, 04:03 AM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
The #1 cylinder for the motor is on the driver side, nearest the radiator. Without knowing how the distributor is installed, #1 could be anywhere. Pull the plugs out so the motor is easier to turn. Get the correct socket and ratchet that fits the bolts for the harmonic balancer. Cover the #1 plug hole with your finger and turn the motor slowly with the ratchet. When you feel compression, watch for the timing mark on the harmonic balancer and bring it in line with the pointer. Pull the distributor cap and see where the rotor is pointing, that will be where #1 needs to start. Start with #1 plug wire and work clockwise around the distributor 1-8-4-3-6-5-7-2
