Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what are the symptoms of having the wrong #1 cylinder
Old 06-20-2012, 07:21 AM
timothale timothale is offline
Wiki Edits: 27
what engine ?
some engines had Number one on the second crank throw, some numbered all on one side 1234 then the other side 5678. other engines alternate side to side, I put a Buick Nailhead in my willys, Nailheads have the passenger side cylinder front on the block, made the left rear closer to the steering gear in my engine swap in a 56 chevy truck, I checked the rotor position for No 1 in the willys , Then routed the wires and locations and distributor rotation like Ford engines I was used to working on . It started and ran , crappy but would run. I got a shop tune up manual, did it right, I found that about 5 wires were firing correctly. l
