Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what are the symptoms of having the wrong #1 cylinder
Old 06-20-2012, 04:49 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by timothale
some engines had Number one on the second crank throw, some numbered all on one side 1234 then the other side 5678. other engines alternate side to side, I put a Buick Nailhead in my willys, Nailheads have the passenger side cylinder front on the block, made the left rear closer to the steering gear in my engine swap in a 56 chevy truck, I checked the rotor position for No 1 in the willys , Then routed the wires and locations and distributor rotation like Ford engines I was used to working on . It started and ran , crappy but would run. I got a shop tune up manual, did it right, I found that about 5 wires were firing correctly. l
His post said 350 Chevy so #1 is the front left (driver side).
