Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what temp to have my electric fans come on?
Old 08-16-2012, 04:18 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
What engine? The older engines were not designed to run at a high temp. The newer engines run at a higher temp as designed. If it's an older engine (computerless), I would have them come on at around 210ish. If it's a newer type, 230ish would be safe. Also, make sure you put the correct thermostatic switch in. I installed a switch in an older SBC 350 but it would not work. Come to find out the switch was made for a computerized system. It does make a difference. Good Luck.
The Following User Says Thank You to S10 Racer For This Useful Post:
the82elco (08-16-2012)
