What temp for a power coat oven??. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2013, 10:33 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
What temps should I shoot for for a power coat oven??Aluminum parts or steel parts??. I am looking at his one:
Lab Oven/Curing Oven
Sure seems like 700 is all full hot!!!.
Old 02-25-2013, 11:31 AM
1Gary's Avatar
Spelling error-should read powder coat.
Old 02-25-2013, 11:42 AM
Joe G's Avatar
When we powdercoat, we preheat the oven (and part if it's thick) to 450. Coat the part and put it in the 450 degree oven for 4-5 minutes (until the powder becomes glossy), and then reduce the heat to 400 and let it bake for 20 minutes. We only do small parts, So our oven is just an electric range we found on Craig's List for $50.
Hope this helps...
Old 02-25-2013, 11:59 AM
1Gary's Avatar
One of the things that does concern me is like for aluminum rims.I do want the best coating I can get in the longevity and finish,but I do think about distortion baking the part too hot.
The seller emailed me back telling me that oven's heat range is from 250 to 700.
Old 02-25-2013, 12:34 PM
BOBCRMAN@aol.com's Avatar
I also do many small parts. Different powders require various heats. Manufacturer of powder usually states desired temp in their tech sheets. Usually 425-250 degrees.
Old 02-26-2013, 12:13 PM
1Gary's Avatar
Well I got this email back from the seller:
Gary,
Internal dimensions measure 14"x14"x14".
The manufacturer is Blue M Electric Company.
At first I was going to ask you guys had ever heard of that company.Then I did a search on Ebay and found this:
blue-m oven | eBay
So I think I'll pass on this one.Aside from the things I want it for myself,I was considering taking in side work in my personal shop like the size of wheels on down.What you guys think about that??.
Old 02-26-2013, 01:27 PM
I bought my oven from the local Habitat for Humanities (Re-store). $25.00 and works great. An old sixties built in electric wall oven. i set it on a couple of cement blocks and wired it up to 220 and started coating. Big enuff to do a wheel. But I usually just do trim and valve covers etc.
homemade powder coat oven cutthroatkid Garage - Tools 23 03-10-2015 10:34 PM
Powdercoating without oven mitmaks Hotrodding Basics 16 06-20-2012 06:55 AM
Industreal oven juanster Garage - Tools 12 11-26-2011 07:05 AM
Power steering temp root Engine 0 11-07-2003 10:49 PM
anything better than oven cleaner? anthony herrera Body - Exterior 7 05-22-2003 05:28 PM
