What temp thermostat do i run with sbc w/6-71? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 06:00 PM
blown67's Avatar
I was just wondering if you guys could help me and tell me what temp thermostat i should run with my 355 w/6-71 blower
Old 08-29-2010, 02:48 AM
badknuckles's Avatar
you talkin to me?
surprised no one has replied to this, i would go with 160
Old 08-29-2010, 05:51 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Mine runs fine with a 180...
Old 08-29-2010, 10:58 AM
blown67's Avatar
Ok thanks I have a 160 in there right now but i just wanted to see what everybody else runs
Old 08-29-2010, 11:00 AM
blown67's Avatar
one other thing how much play are you suppose to have in your blower belt?
Old 08-29-2010, 11:26 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I run about half an inch deflection along the long side, cold.
Semper Fi
Old 08-30-2010, 08:57 PM
bentwings's Avatar
bentwings
A better way is about 1/2 inch when hot on the long side , especially with aluminum heads. I need at least an inch cold. Even more when really cold like 20 deg.
I run a 8mm metric belt and generally run it even more snug when hot. It cuts down the noise a bit and doesn't seem to wear the pulleys as much. I have over 9000 miles on it this year already. I adjusted it at about 1000 miles and haven't done a thing to it since.
In industy we ran the very same belts much tighter. After all they are very precision timing belts. Running them loose causes slop in the timing events.
Anyone run a Pete jackson noisy gear drive in a sbc? batman09 Engine 60 01-24-2006 01:17 AM
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
What Temp Thermostat and Urban Myth? erichb Engine 4 12-02-2004 11:09 PM
434 sbc...what fuel system should i run? 68SSMaro Engine 5 05-08-2004 03:10 AM
What cam do you run in your SBC? western star Engine 12 10-04-2003 07:59 PM
