What are these in the pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 02:35 AM
wein77's Avatar
This is a new TCI TH350 trany. It only has about 250 miles on it. I was driven and had the car in 2nd gear then I heard a sound come from my trany and when the shift to 3rd gear the trany acted like it was in 1st gear. I ended opening up my trany pan and found these pieces in their.
What type of TH350 was it? TCI StreetFighter BOP Transmission 311100
By this I mean what did they spec the trans to as far as power handling and severity of service? Ideal for engines producing 450 HP with a non-supercharged system.
Valve body mods? No just what it came with. Equipped with a manual/automatic valve body
Street / Strip? Daily Driver
Trans brake? No
Nitrous? No
Cooler? Yes
Convertor? Hughes 2500
What size engine and how much HP and Torque do you have in front of it? 76 Pontiac 350 has not been bored out, with Edelbrock Performer Intake Manifolds, Holley 700 double pump carb, Competition Cams Xtreme Energy Cam Advertised Duration 262/ 270, Lift .462/ .470, Competition Cams Hydraulic Flat Tappet lifter, Competition Cams Magnum Steel Roller Tip Rockers Arms 1.52 Ratio, Competition Cams Magnum Pushrods 9.300 in, Summit headers
Your driving style? I do not speed, or drive like a bad *** out of hell.
Neutral drops? No (no burn outs either)
I have still been letting the camshaft and lifters breakin. For the price of shipping I could also go down to Advance Auto parts and get one of there TH350 for $412, $200 core charge. 18 month warranty. If the trany messes up then just take it to the local Auto parts store and not ship it out like TCI, It is not even worth paying the freight charge
http://www.cardomain.com/member_page...33_56_full.jpg
I wonder how many other people have had problems with TCI
Old 06-13-2006, 05:27 AM
Last journal entry: PICTURE TEST
parts
I would like to help but i cannot see any pictures..
Keith
Old 06-13-2006, 09:16 AM
302 Z28's Avatar
Me neither.
Vince
Old 06-13-2006, 03:45 PM
wein77's Avatar
here is my cardomain site that has pictures of my trany on it
http://www.cardomain.com/ride/2048633/6
Old 06-13-2006, 04:10 PM
Jmark's Avatar
Here is the picture in question.
If the flat pieces are brass, the sprag let go. Most likely the outer race cracked and the sprag got demolished. Not a good thing. Hope TCI stands behind the trans.
Mark
Old 06-13-2006, 04:46 PM
302 Z28's Avatar
Man that can't be good .
Vince
Old 06-13-2006, 06:39 PM
Jmark's Avatar
Vince
Nope, that aint good! When I was looking for my core 700, the trans shop pulled the pan off one that looked just like that, plus it had planet parts in it too! I passed and had them pull another. Got a good one after 3 trannys.
Old 06-14-2006, 02:28 AM
wein77's Avatar
thanks everyone. I will fill you in once I find out
Old 06-14-2006, 05:09 AM
parts
yep, it's the sprag. the bigger piece in to upper right of the picture is part of the out race of the intermediate sprag..
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 07:21 PM
power glide pan capacity aluminum pan jsteve068 Transmission - Rearend 2 02-22-2006 06:42 PM
8BA flathead oil pan cleanout plate powerrodsmike Engine 0 09-13-2005 04:52 AM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
