-   -   What is this thing? (http://www.hotrodders.com/forum/what-thing-216832.html)
Silver Surfer 03-17-2012 12:16 AM
What is this thing?
1 Attachment(s)
This is a GM Metric Saginaw power steering pump from an '81 C-10. I think a couple billion were made, so SOMEONE has to know what this screw/bolt is/does on the back of the unit. Does it adjust pressure? How do you set it? Is it OK to zing it on and off with an impact wrench? I tried moderate pressure with a ratchet and stopped before I busted my knuckles!
bondo 03-17-2012 05:28 AM
Ayuh,.... That's just a mountin' stud.....
In some applications, it's the tensionin' stud...
TroyBoy 03-17-2012 05:37 AM
LOL, x2. Yep, its a mounting stud.
joe_padavano 03-18-2012 10:15 AM
Actually, it does two things. Yes, it's a mounting stud. It also holds the sheet metal reservoir to the cast pump body. You need to swap it from the old pump to the rebuilt one.
Silver Surfer 03-19-2012 10:42 AM
Thanks guys! I got this sorted out!
