What is this thing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2012, 12:16 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
What is this thing?
This is a GM Metric Saginaw power steering pump from an '81 C-10. I think a couple billion were made, so SOMEONE has to know what this screw/bolt is/does on the back of the unit. Does it adjust pressure? How do you set it? Is it OK to zing it on and off with an impact wrench? I tried moderate pressure with a ratchet and stopped before I busted my knuckles!
Old 03-17-2012, 05:28 AM
bondo's Avatar
Ayuh,.... That's just a mountin' stud.....
In some applications, it's the tensionin' stud...
Old 03-17-2012, 05:37 AM
TroyBoy's Avatar
Psychomotors
LOL, x2. Yep, its a mounting stud.
Old 03-18-2012, 10:15 AM
Actually, it does two things. Yes, it's a mounting stud. It also holds the sheet metal reservoir to the cast pump body. You need to swap it from the old pump to the rebuilt one.
Old 03-19-2012, 10:42 AM
Thanks guys! I got this sorted out!
What is this thing? Blackdog Hotrodders' Lounge 15 10-10-2008 10:50 AM
If it ain't one thing, it's another! 41willys Hotrodders' Lounge 7 07-01-2008 04:04 PM
Is this a good thing or a bad thing? Rob Keller Off-Topic 4 04-30-2007 09:54 PM
Who Said No Such Thing As Bad Gas 1BAD80 Hotrodders' Lounge 4 11-20-2004 08:04 PM
Can anyone help me with 1 thing. Rubberman2003 General Rodding Tech 3 08-31-2003 02:43 PM
